How to Fix A Stripped Screw Hole
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: step 1, image 1 of 1
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: step 2, image 1 of 2 How to Fix A Stripped Screw Hole: step 2, image 2 of 2
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: step 3, image 1 of 2 How to Fix A Stripped Screw Hole: step 3, image 2 of 2
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: step 4, image 1 of 1
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: step 5, image 1 of 1
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: step 6, image 1 of 2 How to Fix A Stripped Screw Hole: step 6, image 2 of 2
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Your screw should now hold secure.
Isaiah Valdez Mireles
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 67
All Time: 1,470
