How to Change Strings on a Ukulele
  1. How to Change Strings on a Ukulele, String: step 1, image 1 of 1
    • Start by loosening the string you are trying to replace by twisting the pegs.
    • The G and C tuning pegs turn up to tighten and down to loosen while the E and A tuning pegs turn down to tighten and up to loosen.
  2. How to Change Strings on a Ukulele: step 2, image 1 of 1
    • Next, grab the new string you are using to replace.
    • The packaging will inform you of which string replaces which note—some are different than others so pay attention!
  3. How to Change Strings on a Ukulele: step 3, image 1 of 1
    • Feed the string through the tie block.
    • Remember to leave slack.
  4. How to Change Strings on a Ukulele: step 4, image 1 of 1
    • Wrap the string over the tie block and back underneath itself.
  5. How to Change Strings on a Ukulele: step 5, image 1 of 2 How to Change Strings on a Ukulele: step 5, image 2 of 2
    • Recross the string over itself again, looping it two or three more times.
  6. How to Change Strings on a Ukulele: step 6, image 1 of 1
    • Pinch the string and pull tightly.
  7. How to Change Strings on a Ukulele: step 7, image 1 of 1
    • Now, fasten the string back to the headstock. To do this, feed the string through the hole in the turning peg.
  8. How to Change Strings on a Ukulele: step 8, image 1 of 1
    • Twist again to tighten and cut off extra string once complete.
Finish Line
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 28
All Time: 544
