How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 1, image 1 of 1
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 2, image 1 of 1
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 3, image 1 of 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 3, image 2 of 2
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 4, image 1 of 1
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 5, image 1 of 2 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 5, image 2 of 2
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 6, image 1 of 1
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 7, image 1 of 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 7, image 2 of 3 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: step 7, image 3 of 3
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
Finish Line
2 other people completed this guide.
Md Abdullah
201 Reputation
1 Guide authored
One Comment
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - Reply
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 209
All Time: 4,339
