How to Adjust Cantilever Bicycle Brakes
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: step 1, image 1 of 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: step 1, image 2 of 3 How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: step 1, image 3 of 3
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: step 2, image 1 of 2 How to Adjust Cantilever Bicycle Brakes: step 2, image 2 of 2
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: step 3, image 1 of 3 How to Adjust Cantilever Bicycle Brakes: step 3, image 2 of 3 How to Adjust Cantilever Bicycle Brakes: step 3, image 3 of 3
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: step 4, image 1 of 1
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: step 5, image 1 of 2 How to Adjust Cantilever Bicycle Brakes: step 5, image 2 of 2
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: step 6, image 1 of 2 How to Adjust Cantilever Bicycle Brakes: step 6, image 2 of 2
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: step 7, image 1 of 2 How to Adjust Cantilever Bicycle Brakes: step 7, image 2 of 2
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: step 8, image 1 of 1
    • Flip the bike back onto its wheels.
Go ride your bike!
Devaughantee
194 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 37
All Time: 759
