How To Replace Ski Pole Baskets
  1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: step 1, image 1 of 2 How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: step 1, image 2 of 2
    • Place the sock over your hand like a glove.
    • You will be using this hand to pull off the heated basket.
  2. How To Replace Ski Pole Baskets: step 2, image 1 of 2 How To Replace Ski Pole Baskets: step 2, image 2 of 2
    • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
    • Heat for no longer then three minutes.
  3. How To Replace Ski Pole Baskets: step 3, image 1 of 2 How To Replace Ski Pole Baskets: step 3, image 2 of 2
    • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
  4. How To Replace Ski Pole Baskets: step 4, image 1 of 2 How To Replace Ski Pole Baskets: step 4, image 2 of 2
    • Heat an all purpose glue stick with a lighter.
  5. How To Replace Ski Pole Baskets: step 5, image 1 of 2 How To Replace Ski Pole Baskets: step 5, image 2 of 2
    • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
    • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
  6. How To Replace Ski Pole Baskets: step 6, image 1 of 1
    • Reheat the replaced basket with a hair dryer for a minute.
    • After heating, allow the glue to cool and set for 10 minutes.
  7. How To Replace Ski Pole Baskets: step 7, image 1 of 1
    • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
Lia Garkie
131 Reputation
1 Guide authored
Cal Poly, Team 30-3, Green Spring 2015 Member of Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 17,065
