How Fix Rattle in Aftershokz Trekz Titanium Headphones
  1. How Fix Rattle in Aftershokz Trekz Titanium Headphones, mark the location for a glue port: step 1, image 1 of 1
    • Using an awl or drift punch, mark a central location above the back of the speaker.
    • This step centers the drill bit so it doesn't wander.
    • The exact location is not critical, as the speaker fills most of the cavity. This port will be filled with glue, so maintain some distance from the control button.
  2. How Fix Rattle in Aftershokz Trekz Titanium Headphones, Drill a small glue port: step 2, image 1 of 1
    • Gently by hand using a small twist bit, cleanly penetrate the plastic case. Stop when metal is visible.
    • There is an air-gap between the case and the back of the speaker.
  3. How Fix Rattle in Aftershokz Trekz Titanium Headphones: step 3, image 1 of 1
    • Optionally ream the mouth of the glue port.
    • I used a countersink. Generally an oversized twist bit can serve the purpose.
  4. How Fix Rattle in Aftershokz Trekz Titanium Headphones: step 4, image 1 of 1
    • apply a single drop of glue
    • Here I successfully used Gorilla Glue. Other glue or epoxy products have been used by others. The objective is to fill in behind the speaker and/or adhere the flange of the speaker to the cup.
  5. How Fix Rattle in Aftershokz Trekz Titanium Headphones, Fill behind the speaker with glue/epoxy: step 5, image 1 of 1
    • work the adhesive into the glue port for example using a toothpick.
  6. How Fix Rattle in Aftershokz Trekz Titanium Headphones, Remove excess adhesive: step 6, image 1 of 1
    • clean up any excess glue or epoxy.
  7. How Fix Rattle in Aftershokz Trekz Titanium Headphones, Seal as necessary: step 7, image 1 of 1
    • Gorilla glue can foam, so I taped over the glue port temporarily while the glue dried overnight.
Finish Line
3 other people completed this guide.
Student4Life
2,613 Reputation
7 Guides authored
2 Comments
Plz how to cornet wire to d panel plz diagram
kca - Reply
Aftershock panel ( Diagram)
kca - Reply
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 159
All Time: 8,119
