Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement
  1. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement, Motor Mount: step 1, image 1 of 2 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement, Motor Mount: step 1, image 2 of 2
    • While holding the propeller in place with your other hand, unscrew the single Phillips screw securing the front nose tip.
  2. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 2, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 2, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 2, image 3 of 3
    • While holding the propeller in place, remove the front propeller assembly from the motor by loosening the hex nut.
    • It is encouraged to loosen but not completely remove the hex nut: loosening the nut allows the propeller assembly to be removed from the plane, but it's best to keep the propeller assembly as one piece (see last photo).
  3. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 3, image 1 of 1
    • Working with screws can result in small metal splinters.
    • Put gloves on for safety.
  4. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 4, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 4, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 4, image 3 of 3
    • Unscrew the three Phillips screws that secure the hull.
  5. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 5, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 5, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 5, image 3 of 3
    • Remove the hull and locate the 4 screws that support the motor.
  6. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 6, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 6, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 6, image 3 of 3
    • Remove the four Phillips screws and carefully remove the broken motor mount.
  7. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 7, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 7, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 7, image 3 of 3
    • Remove the four Phillips screws under the motor mount.
  8. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 8, image 1 of 1
    • Remove the broken motor mount.
  9. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 9, image 1 of 1
    • 3D print the replacement motor mount. Ifixit does not allow .stl or .3mf files to be imported, so Google Drive links to the files are given below.
    • If you do not have a 3D printer, try your local library or high school. Otherwise, google any of these: Protolabs, Shapeways, PCBWay, JLCPCB, or just google “3d printing service” (these cost money). When prompted, ask them to use PLA filament on an FDM 3D printer.
    • If you own a 3D printer: convert the .stl file into a .gcode file by using a slicer software such as Cura. If needed, look up Youtube videos on how to use your specific 3D printer. If needed, rotate the object along its z-axis in the slicer software until it matches the orientation in the image relative to the x, y, and z axes (very important).
    • If needed, resize it so the x, y, and z dimensions of the part are 39x39x15mm. In the image the x, y, z axes are red, green, and blue respectively. Also, the .3mf file is posted in case anyone wants to edit it in Fusion 360 (shouldn't be necessary).
    • STL file: https://drive.google.com/file/d/1edjSS3a...
    • 3MF file: https://drive.google.com/file/d/1IEwvLOI...
  10. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 10, image 1 of 1
    • Replace the broken part with the 3D-printed replacement.
    • Due to varying tolerances between different 3D printers, it may be necessary to enlarge the center hole slightly with a drill if the motor can't spin freely.
  11. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 11, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 11, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 11, image 3 of 3
    • Screw the 4 motor mount screws into the replacement mount.
    • Screw the second opposite to the first screw to ensure alignment!
  12. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 12, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 12, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 12, image 3 of 3
    • Screw the replacement mount back onto the body of the RC Plane.
  13. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 13, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 13, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 13, image 3 of 3
    • Attach the hull back onto plane body with the three screws removed previously.
  14. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 14, image 1 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 14, image 2 of 3 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 14, image 3 of 3
    • Reattach, screw, and secure the propeller assembly back onto the plane.
  15. Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 15, image 1 of 2 Horizon Hobby Mini Apprentice S RC Plane Motor Mount 3D-Printed Replacement: step 15, image 2 of 2
    • Resecure the nose tip.
Finish Line
Ryan Hang
265 Reputation
1 Guide authored
UC Davis, Team 1-6, Morris Winter 2024 Member of UC Davis, Team 1-6, Morris Winter 2024
UCD-MORRIS-W24S1G6
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 41
All Time: 116
