Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement
  1. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: step 1, image 1 of 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: step 1, image 2 of 3 Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement, Brush Roll: step 1, image 3 of 3
    • Push the red release lever to the right.
    • Turn the red switch counterclockwise.
    • Tilt the bottom of the plastic tray out towards you and pull it off the vacuum.
  2. Hoover T-Series WindTunnel Pet UH70102 Brush Roll Replacement: step 2, image 1 of 1
    • Pull the brush roll out of vacuum.
    • Remove the belt from brush roller
Sophia Stockburger
566 Reputation
5 Guides authored
Cal Poly, Team S11-G2, Banghart Winter 2018 Member of Cal Poly, Team S11-G2, Banghart Winter 2018
CPSU-BANGHART-W18S11G2
5 Members
9 Guides authored
3 Comments
When you turn the vacuum on the brush roller works until you release the handle to start vacuuming then the brush roller stops. How do I correct this issue?
Brenda Brenda - Reply
Did you ever get an answer on this issue or figure it out? I am having the same problem!
Val -
Mine does the same thing. I have replaced the belt but that didn’t help
Ann - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,002
