Hoover LiNX The Nozzle Prongs Replacement
  1. Hoover LiNX The Nozzle Prongs Replacement, Replace The Motor: step 1, image 1 of 1
    • Detach the rolling assembly from the body by pushing the button found at the base.
  2. Hoover LiNX The Nozzle Prongs Replacement: step 2, image 1 of 1
    • Remove the seven 7.5mm Phillips #1 screws from the brush retainer.
  3. Hoover LiNX The Nozzle Prongs Replacement: step 3, image 1 of 2 Hoover LiNX The Nozzle Prongs Replacement: step 3, image 2 of 2
    • Remove the brush and retainer from the rolling assembly.
    • The brush will need to be disconnected from the belt.
  4. Hoover LiNX The Nozzle Prongs Replacement: step 4, image 1 of 1
    • Remove the eight 4mm Phillips #1 screws from the bottom panel.
  5. Hoover LiNX The Nozzle Prongs Replacement: step 5, image 1 of 1
    • Remove the bottom panel.
  6. Hoover LiNX The Nozzle Prongs Replacement: step 6, image 1 of 1
    • Remove the motor.
  7. Hoover LiNX The Nozzle Prongs Replacement, The Nozzle Prongs: step 7, image 1 of 1
    • Remove the two 7.5mm Phillips #1 screws from the main body.
  8. Hoover LiNX The Nozzle Prongs Replacement: step 8, image 1 of 1
    • Remove the black covering from the air tube.
  9. Hoover LiNX The Nozzle Prongs Replacement: step 9, image 1 of 1
    • Slide the prongs out through their channels.
  10. Hoover LiNX The Nozzle Prongs Replacement: step 10, image 1 of 2 Hoover LiNX The Nozzle Prongs Replacement: step 10, image 2 of 2
    • Remove the angled neck and feed the prongs out through their channels.
  11. Hoover LiNX The Nozzle Prongs Replacement: step 11, image 1 of 2 Hoover LiNX The Nozzle Prongs Replacement: step 11, image 2 of 2
    • Replace the prongs.
2 other people completed this guide.
Sara Vlhova
541 Reputation
4 Guides authored
USF Tampa, Team S7-G4, Passmore Spring 2018 Member of USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Members
12 Guides authored
2 Comments
How do I get to the receivers for the prongs? They appear to be too loose to make a connection and i have not been able to get into the body to tighten. Is there another way to improve this connection?
Robert L Worthing - Reply
Thank you for asking ifixit your 11/1018 question. I’ve been trying to disassemble the body to get at the receiver(s)/socket(s) for those prongs for days. And ifixit, please, have you got a picture of the routing of the brush motor wires from the motor through the rolling assembly, the swiveling universal joint, and along the back of the airtube?
donwesel - Reply
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 39
All Time: 1,744
