Hoover LiNX The Motherboard Inside The Handle Replacement
  1. Hoover LiNX The Motherboard Inside The Handle  Replacement, Hoover LiNX Handle Teardown: step 1, image 1 of 1
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 2, image 1 of 1
    • Remove the handle by pulling it up.
  3. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 3, image 1 of 1
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 4, image 1 of 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 5, image 1 of 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: step 5, image 2 of 2
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 6, image 1 of 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: step 6, image 2 of 2
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX The Motherboard Inside The Handle  Replacement, The Motherboard Inside The Handle: step 7, image 1 of 1
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 8, image 1 of 1
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX The Motherboard Inside The Handle  Replacement: step 9, image 1 of 2 Hoover LiNX The Motherboard Inside The Handle  Replacement: step 9, image 2 of 2
    • Carefully pull the motherboard out with its attached wires.
Sara Vlhova
541 Reputation
4 Guides authored
USF Tampa, Team S7-G4, Passmore Spring 2018 Member of USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 19
All Time: 921
