Honeywell Turbo Force Air Circulator Fan Disassembly
  1. Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: step 1, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Overview: step 1, image 2 of 2
    • Honeywell Turbo Force 12" Air Circulator.
    • Dimensions - 11.22" x 9.8" x 13.98", 5.7 lbs.
  2. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: step 2, image 1 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: step 2, image 2 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Scews: step 2, image 3 of 3
    • Remove the 6 screws from the backside of the fan.
  3. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: step 3, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the grill: step 3, image 2 of 2
    • Remove the front grill cover.
  4. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: step 4, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the plastic ring: step 4, image 2 of 2
    • Remove the inside plastic ring around center shaft.
    • Enables the fan blades to be removed.
    • Use a flat head screwdriver to remove the plastic ring.
  5. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: step 5, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing Fan blades: step 5, image 2 of 2
    • Remove the fan blades by pulling.
  6. Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: step 6, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Detaching wire covering: step 6, image 2 of 2
    • Remove 1 screw inside to detach the plastic wire covering.
  7. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the wire protector piece: step 7, image 1 of 1
    • Remove the plastic covering.
  8. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: step 8, image 1 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: step 8, image 2 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the motor: step 8, image 3 of 3
    • Remove the 2 screws on the motor.
    • This allows the motor to pull away from the housing.
  9. Honeywell Turbo Force Air Circulator Fan Disassembly, Pulling the Motor from the Housing: step 9, image 1 of 1
    • Pull the motor away from the housing to expose wiring.
    • Use caution to not detach the wiring from the back.
  10. Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: step 10, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Unscrewing the Rotor: step 10, image 2 of 2
    • Remove the two screws from the back of the motor.
    • Allows the rotor and front/back bearings to be removed.
  11. Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: step 11, image 1 of 2 Honeywell Turbo Force Air Circulator Fan Disassembly, Removing the Rotor: step 11, image 2 of 2
    • Remove the rotor and front bearings by pulling.
  12. Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: step 12, image 1 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: step 12, image 2 of 3 Honeywell Turbo Force Air Circulator Fan Disassembly, Realigning the Bearings: step 12, image 3 of 3
    • During reassembly, re-align the bearings by tapping on the shaft.
To reassemble the fan, follow these instructions in reverse order. Note that Step 12 is an extra step in the reassembly process to follow.
2 other people completed this guide.
Donovan Williams
262 Reputation
1 Guide authored
2 Comments
Thank you for the good guide, I saved my fan in the middle of hot weather!
Noah - Reply
I have a Honeywell HF910. I have taken the cover off but there are no screws behind the fan blades. Any suggestions on how to remove the fan blades? Thank you.
Nancy Alexander - Reply
Past 24 Hours: 30
Past 7 Days: 149
Past 30 Days: 635
All Time: 7,264
