Holley 4 Barrel Carburetor Gasket Replacement
  1. Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: step 1, image 1 of 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: step 1, image 2 of 3 Holley 4 Barrel Carburetor Gasket Replacement, Gaskets: step 1, image 3 of 3
    • Make sure your carburetor has no fuel inside.
  2. Holley 4 Barrel Carburetor Gasket Replacement: step 2, image 1 of 1
    • Remove the four 47 mm flat head screws.
  3. Holley 4 Barrel Carburetor Gasket Replacement: step 3, image 1 of 1
    • Remove the bowl from the side of the carburetor.
  4. Holley 4 Barrel Carburetor Gasket Replacement: step 4, image 1 of 1
    • Remove the four 63 mm flat head screws.
  5. Holley 4 Barrel Carburetor Gasket Replacement: step 5, image 1 of 1
    • Remove the bowl and the steel fuel line from the side of the carburetor.
  6. Holley 4 Barrel Carburetor Gasket Replacement: step 6, image 1 of 2 Holley 4 Barrel Carburetor Gasket Replacement: step 6, image 2 of 2
    • Remove the spacer from the side of the carburetor.
    • If you need to, use a flat head screwdriver and carefully pry the spacer off of the carburetor.
  7. Holley 4 Barrel Carburetor Gasket Replacement: step 7, image 1 of 1
    • Remove the six 2.5 mm hex screws from the secondary metering block.
    • If you need to, use the small flat head screwdriver that will fit the head of the hex screws in order to remove the screws.
  8. Holley 4 Barrel Carburetor Gasket Replacement: step 8, image 1 of 1
    • Using a flat head screwdriver, remove the thin gasket from the side of the carburetor.
  9. Holley 4 Barrel Carburetor Gasket Replacement: step 9, image 1 of 2 Holley 4 Barrel Carburetor Gasket Replacement: step 9, image 2 of 2
    • Remove the eight 20 mm Phillips screws from the bottom plate of the carburetor.
    • Then, carefully remove the gasket from the bottom plate. Use a flat head screwdriver, if needed, to pry the gasket off of the plate.
4 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 49
All Time: 4,365
