Heyday True Wireless Earbuds 8204 Case Motherboard Replacement
  1. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement, Case Motherboard: step 1, image 1 of 1
    • Use a spudger or other prying tool to gently pry open the case from the metal hinge that connects the white part of the top and bottom of the case together.
    • Screwdrivers shouldn't be used as pry tools as they can damaged delicate internal components.
  2. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: step 2, image 1 of 1
    • Using the spudger, going from the back of the case where the hinge used to be, pry the earbud charging housing up and remove it.
  3. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: step 3, image 1 of 1
    • Use a Torx screwdriver to gently remove the six screws on the silver ring that holds in the motherboard and charging station.
  4. Heyday True Wireless Earbuds 8204 Case Motherboard Replacement: step 4, image 1 of 1
    • Pull the silver bracket from the base of the case to reveal the motherboard.
    • Lift up and pull the motherboard out of the case.
Ben Davignon
493 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Petersen Fall 2022 Member of UMass Dartmouth, Team 1-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G3
6 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 148
