Heyday True Wireless Earbuds 8204 Battery Replacement
  1. Heyday True Wireless Earbuds 8204 Battery Replacement, Battery: step 1, image 1 of 1
    • Pinch the tip of the earbud in one hand while gripping the base of the earbud in the other.
    • Gently pull the tip of the earbud apart from the base.
    • These pieces should come apart without the need for tools. Do not be afraid to use a little force.
  2. Heyday True Wireless Earbuds 8204 Battery Replacement: step 2, image 1 of 2 Heyday True Wireless Earbuds 8204 Battery Replacement: step 2, image 2 of 2
    • Put the base of the earbud aside as it will not be needed to access the speaker.
    • Gently pull the battery out from the earbud housing to reveal the wire that connects the two.
    • Do not pull the speaker forcefully. This may pull the wire out in a manner that damages the device.
  3. Heyday True Wireless Earbuds 8204 Battery Replacement: step 3, image 1 of 1
    • Desolder the board connection to separate the red wire.
    • With the connection properly severed, pull the speaker unit out of the housing fully.
Peter Rocha
292 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Petersen Fall 2022 Member of UMass Dartmouth, Team 1-3, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G3
6 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 468
