Introduction
The headphones wouldn't operate or connect to your smartphone without the battery. If your gadget won't power on, the battery might need to be changed. To change the battery, refer to this manual.
Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
