Hatch Restore Bottom Circuit Board Replacement
  1. Hatch Restore Bottom Circuit Board Replacement, Intro: step 1, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement, Intro: step 1, image 2 of 2
    • Replacing your bottom circuit board will be easy.
  2. Hatch Restore Bottom Circuit Board Replacement: step 2, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement: step 2, image 2 of 2
    • Peel away the rubber feet.
  3. Hatch Restore Bottom Circuit Board Replacement: step 3, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement: step 3, image 2 of 2
    • Remove the indicated 8 screws.
    • You may need to remove some adhesive from the screws to remove them.
  4. Hatch Restore Bottom Circuit Board Replacement: step 4, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement: step 4, image 2 of 2
    • Pry off the bottom cover.
  5. Hatch Restore Bottom Circuit Board Replacement: step 5, image 1 of 1
    • Remove the 6 indicated screws.
  6. Hatch Restore Bottom Circuit Board Replacement: step 6, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement: step 6, image 2 of 2
    • Remove the power cable
    • There is a ribbon cable under the board. Do not pull the circuit board too far from the device.
  7. Hatch Restore Bottom Circuit Board Replacement: step 7, image 1 of 2 Hatch Restore Bottom Circuit Board Replacement: step 7, image 2 of 2
    • Push the black tabs on the ZIF connector towards the cable, then remove the cable.
    • The cable should have no resistance when pulled out. Do not forcefully remove the cable.
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 226
