Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement
  1. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Start: step 1, image 1 of 1
    • Empty the kettle and make sure nothing is coming out of the switch (some condensation is expected to escape from there)
  2. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Base plate disassembly: step 2, image 1 of 1
    • Remove the two Phillips screws (circled in red on the picture) and use a triangular bit to remove the third screw (circled in green on the picture)
  3. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Extracting the strip from the replacement control terminal: step 3, image 1 of 2 Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Extracting the strip from the replacement control terminal: step 3, image 2 of 2
    • I couldn’t find just the bimetallic switch, so I purchased instead a replacement temperature control terminal for another type of Kettle on Amazon. The strip appeared to be pretty standard and slides right out when you lift it from the bottom notch.
  4. Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Replacing the strip: step 4, image 1 of 2 Hario V60 Drip Kettle "Buono" Bimetallic strip Replacement, Replacing the strip: step 4, image 2 of 2
    • You can remove the old corroded strip from the kettle (red circle on the picture). Simply lift it from the little notch on the bottom (green circle on the picture).
    • Then you can slide in the replacement strip, with the middle metal tongue facing up. Make sure to slide it under the two plastic side guides.
    • When the water boils in the kettle, steam is sent through inner tubing down to the bimetallic strip. The strip will change shape with the heat, the tong will flip down, and trip the switch.
4 other people completed this guide.
cortig
661 Reputation
1 Guide authored
5 Comments
Extremely useful and saved us buying a new kettle. Thank you!
Melanie M - Reply
The part is not available on Amazon. Anyone know of another source?
Richard O'Brien - Reply
found the part finally and worked perfectly. I contacted the company, they were nice but not much help. Everything is disposable these days based on the way companies treat and make products.
Hi there! Where did you find the part, Richard?
Morgan Curtis -
Yes curious what part you found...
Ethan Miller -
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 56
All Time: 1,965
