Happrun H1 Cooling Fan Replacement
Video Overview
  1. Happrun H1 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 1
    • Flip the device upside down so that the projector's air filter is facing up.
    • Remove the filter by gently pulling it out until it pops out.
  2. Happrun H1 Cooling Fan Replacement: step 2, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the housing screws.
  3. Happrun H1 Cooling Fan Replacement: step 3, image 1 of 3 Happrun H1 Cooling Fan Replacement: step 3, image 2 of 3 Happrun H1 Cooling Fan Replacement: step 3, image 3 of 3
    • After all the screws are out, insert an opening tool in the small space between the front cover and the back cover and gently lift it up.
    • Remove the covers and set aside.
  4. Happrun H1 Cooling Fan Replacement: step 4, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 4, image 2 of 2
    • Use your hands or an opening tool to disconnect the cables from the source.
    • To disconnect the wires, use the opening tool to lift the lock on the connector and slide the cable out of the connector.
    • Be gentle while pulling the wire to avoid signal loss.
    • These will be colorful wires connected with white plastic clips.
  5. Happrun H1 Cooling Fan Replacement: step 5, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 5, image 2 of 2
    • Gently pull out the fan from below the motherboard and swap it with a new one.
  6. Happrun H1 Cooling Fan Replacement: step 6, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 6, image 2 of 2
    • Reconnect the wires between the fan and the motherboard.
    • Gently push the colorful cables inside the white plastic clips until it gets locked
    • Be gentle while connecting the wires.
  7. Happrun H1 Cooling Fan Replacement: step 7, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 7, image 2 of 2
    • Place the screws in the holes and using a Philip#00 screwdriver gently rotate it until it is tight.
    • Tight the screws properly so that the fan does not come out.
  8. Happrun H1 Cooling Fan Replacement: step 8, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 8, image 2 of 2
    • Now put the cover back in place and tighten the screws using a Philip#00 screwdriver.
    • Make sure the front and the back cover align properly.
  9. Happrun H1 Cooling Fan Replacement: step 9, image 1 of 2 Happrun H1 Cooling Fan Replacement: step 9, image 2 of 2
    • The Cooling fan of the projector has been replaced.
Tulika
196 Reputation
1 Guide authored
3 Comments
Hi Tulika, thank you for the guide!
Is there a chance you can provide me with the messurements of the fan and maybe you know the voltage and RPM's it runs on?
I want to replace it with a quitter one like from Noctua or so.
Thanks!
Illpet - Reply
Any luck doing that? I'm looking for the same solution.
rudyazoulay -
@rudyazoulay, I jsut took apart my projector and this guide is just something weird.
There are 2 turbine type fans
DC Brushless Fan, Model: DFM7530S, DC 12V - 0.25A.
Just put it into google and you will see that one specific. I didn't find the quite one yet.
Illpet - Reply
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 88
All Time: 514
