Introduction
This guide will show you how to remove and replace the RAM in the Hannspree SN12E2 laptop. RAM is to run applications on your device if your device is stalling or running low or even crashing all together this may be the solution.
Remove the RAM access door.
Remove the two 3mm screws using a Phillips #0 screwdriver.
Gently lift on the door out of place.
