Handspring Visor Deluxe PDA Back Cover Replacement
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: step 1, image 1 of 2 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: step 1, image 2 of 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: step 2, image 1 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 2, image 2 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 2, image 3 of 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: step 3, image 1 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 3, image 2 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 3, image 3 of 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: step 4, image 1 of 2 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: step 4, image 2 of 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: step 5, image 1 of 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: step 6, image 1 of 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: step 7, image 1 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 7, image 2 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 7, image 3 of 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: step 8, image 1 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 8, image 2 of 3 Handspring Visor Deluxe PDA Back Cover Replacement: step 8, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the flex strip from the motherboard with tweezers.
Robert
23 Reputation
1 Guide authored
Cal Poly, Team 1-2, Regan SU 2012 Member of Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 589
