HTC Wizard 200 Speakers Replacement
  1. HTC Wizard 200 Speakers Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Speakers Replacement, Battery: step 1, image 2 of 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Speakers Replacement, Back Panel: step 2, image 1 of 1
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Speakers Replacement: step 3, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 3, image 2 of 2
    Spudger
    $3.99
    Buy
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Speakers Replacement: step 4, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 4, image 2 of 2
    T5 Torx Screwdriver
    $5.49
    Buy
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Speakers Replacement: step 5, image 1 of 3 HTC Wizard 200 Speakers Replacement: step 5, image 2 of 3 HTC Wizard 200 Speakers Replacement: step 5, image 3 of 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Speakers Replacement: step 6, image 1 of 2 HTC Wizard 200 Speakers Replacement: step 6, image 2 of 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Speakers Replacement, Speakers: step 7, image 1 of 2 HTC Wizard 200 Speakers Replacement, Speakers: step 7, image 2 of 2
    • Device rotated 180 degrees.
    • Use the plastic opening tool to disconnect the speaker connections.
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 728
