HTC Wizard 200 Motherboard Replacement
  1. HTC Wizard 200 Motherboard Replacement, Battery: step 1, image 1 of 2 HTC Wizard 200 Motherboard Replacement, Battery: step 1, image 2 of 2
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Motherboard Replacement, Back Panel: step 2, image 1 of 1
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Motherboard Replacement: step 3, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 3, image 2 of 2
    Spudger
    $3.99
    Buy
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Motherboard Replacement: step 4, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 4, image 2 of 2
    T5 Torx Screwdriver
    $5.49
    Buy
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Motherboard Replacement: step 5, image 1 of 3 HTC Wizard 200 Motherboard Replacement: step 5, image 2 of 3 HTC Wizard 200 Motherboard Replacement: step 5, image 3 of 3
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Motherboard Replacement: step 6, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 6, image 2 of 2
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Motherboard Replacement, Motherboard: step 7, image 1 of 1
    Spudger
    $3.99
    Buy
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Motherboard Replacement: step 8, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 8, image 2 of 2
    Buy
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Motherboard Replacement: step 9, image 1 of 1
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Motherboard Replacement: step 10, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 10, image 2 of 2
    Spudger
    $3.99
    Buy
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Motherboard Replacement: step 11, image 1 of 2 HTC Wizard 200 Motherboard Replacement: step 11, image 2 of 2
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
Kyle Champ
225 Reputation
12 Guides authored
Cal Poly, Team 20-27, Maness Fall 2011 Member of Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 11
All Time: 1,112
