Introduction
This guide takes you through the steps to install the front panel buttons.
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Tool used on this step:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Remove the four 5mm screws with the T5 Torx screwdriver.
Remove the keyboard slider from the main body.
Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
Almost done!
