HTC HD2 Earpiece Speaker Replacement
  1. HTC HD2 Earpiece Speaker Replacement, Battery: step 1, image 1 of 1
    • Carefully pull the rear cover from the back of the phone.
    • Place a finger beneath the small lip on the left side of the battery.
  2. HTC HD2 Earpiece Speaker Replacement: step 2, image 1 of 2 HTC HD2 Earpiece Speaker Replacement: step 2, image 2 of 2
    • Lay the phone down on it's screen.
    • Lift up on the lip and pull the battery from the phone.
  3. HTC HD2 Earpiece Speaker Replacement, Midframe: step 3, image 1 of 2 HTC HD2 Earpiece Speaker Replacement, Midframe: step 3, image 2 of 2
    • Remove the four black 3.5mm T5 screws from the back of the phone.
  4. HTC HD2 Earpiece Speaker Replacement: step 4, image 1 of 2 HTC HD2 Earpiece Speaker Replacement: step 4, image 2 of 2
    • Insert the flat end of a spudger between the midframe and the display.
    • Slide the spudger along the seam between the frame and the display.
    • Using the spudger for leverage, carefully pry the midframe away from the display assembly.
    • This process will take some effort. Continue to pry slowly and carefully until the frame begins to detach.
    • As it releases, pull the midframe away from the phone.
    • The volume control tab may fall off during removal. It can be easily reattached.
  5. HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 1 of 3 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 2 of 3 HTC HD2 Earpiece Speaker Replacement, Earpiece Speaker: step 5, image 3 of 3
    • Disconnect the small speaker cable from its socket on the motherboard.
    • Remove the earpiece speaker from the phone.
Nathan Puchalski
813 Reputation
5 Guides authored
Cal Poly, Team 24-55, Amido Spring 2011 Member of Cal Poly, Team 24-55, Amido Spring 2011
CPSU-AMIDO-S11S24G55
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 10
All Time: 4,925
