HTC Evo 3D Screen Replacement
  1. HTC Evo 3D Screen Replacement, Motherboard: step 1, image 1 of 3 HTC Evo 3D Screen Replacement, Motherboard: step 1, image 2 of 3 HTC Evo 3D Screen Replacement, Motherboard: step 1, image 3 of 3
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Screen Replacement: step 2, image 1 of 2 HTC Evo 3D Screen Replacement: step 2, image 2 of 2
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by gently pulling down on the bottom of the card.
  3. HTC Evo 3D Screen Replacement: step 3, image 1 of 1
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Screen Replacement: step 4, image 1 of 2 HTC Evo 3D Screen Replacement: step 4, image 2 of 2
    • With the battery, SD card, and screws removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be sure not to rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Screen Replacement: step 5, image 1 of 3 HTC Evo 3D Screen Replacement: step 5, image 2 of 3 HTC Evo 3D Screen Replacement: step 5, image 3 of 3
    • Pictured here is the motherboard.
    • Using precision tweezers, remove the flash mechanism by prying the sides of the piece.
  6. HTC Evo 3D Screen Replacement: step 6, image 1 of 3 HTC Evo 3D Screen Replacement: step 6, image 2 of 3 HTC Evo 3D Screen Replacement: step 6, image 3 of 3
    • Next we will remove the vibration mechanism shown here.
    • Using precision tweezers or fingers, gently pull on the wires connecting the vibration mechanism to the motherboard.
    • The piece should come loose easily.
  7. HTC Evo 3D Screen Replacement: step 7, image 1 of 3 HTC Evo 3D Screen Replacement: step 7, image 2 of 3 HTC Evo 3D Screen Replacement: step 7, image 3 of 3
    • The next step is to disconnect all ribbons attached to the motherboard.
    • Begin by using tweezers to remove the plastic covering the ribbons.
    • Each ribbon needs to be removed by unlocking the white tab and pulling on the ribbon.
    • Unlock by lifting the white tab directly up.
    • The ribbons easily rip and require careful handling.
  8. HTC Evo 3D Screen Replacement: step 8, image 1 of 2 HTC Evo 3D Screen Replacement: step 8, image 2 of 2
    • At this point the motherboard is almost fully detached.
    • Lift the motherboard and using precision tweezers, peel up the insulation cover on the bottom left corner.
  9. HTC Evo 3D Screen Replacement: step 9, image 1 of 3 HTC Evo 3D Screen Replacement: step 9, image 2 of 3 HTC Evo 3D Screen Replacement: step 9, image 3 of 3
    • Disconnect the two ribbons on the backside of the mother board using precision tweezers.
    • Disconnect the Cellular/WIFI antenna by pulling directly up on the black wire.
    • The motherboard will now be free from the rest of the phone.
  10. HTC Evo 3D Screen Replacement, Screen: step 10, image 1 of 1
    • Once the motherboard is removed, heat up the frame of the screen for 30 seconds with a heat gun or a hair dryer. This will make removal easier.
    • Be careful not to overheat the device.
    • Use the plastic opening tool to pry open up one side of the screen.
    • Use the plastic opening tool to move around the borders and loosen the screen.
  11. HTC Evo 3D Screen Replacement: step 11, image 1 of 2 HTC Evo 3D Screen Replacement: step 11, image 2 of 2
    • Use the suction cup to remove the screen off the device.
    • Be careful not to tear off the flex cable.
    • After lifting the screen, begin prying the digitizer using a plastic opening tool.
    • Continue with this process around the entire perimeter of the phone.
  12. HTC Evo 3D Screen Replacement: step 12, image 1 of 2 HTC Evo 3D Screen Replacement: step 12, image 2 of 2
    • Once all the adhesive is separated, carefully remove the screen from the device.
    • Due to the removal of the motherboard, the screens should be easily removed from the phone.
    • Be careful not to cut off the flex cables or the tape.
    • If needed, use heat to make the removal of the tape and cables easier.
6 other people completed this guide.
Carlos De Lima
347 Reputation
1 Guide authored
USF Tampa, Team 14-20, Meier Fall 2015 Member of USF Tampa, Team 14-20, Meier Fall 2015
USFT-MEIER-F15S14G20
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 108
All Time: 1,494
