HTC Droid Eris Battery Replacement
  1. HTC Droid Eris Battery Replacement, Battery: step 1, image 1 of 2 HTC Droid Eris Battery Replacement, Battery: step 1, image 2 of 2
    • Place the device on a flat surface with the headphone outlet facing you.
    • Place the tip of one of your fingers over the highlighted spot.
    • Next, pull the back cover upwards. If this feels difficult, use the spudger.
  2. HTC Droid Eris Battery Replacement: step 2, image 1 of 2 HTC Droid Eris Battery Replacement: step 2, image 2 of 2
    • Lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place.
    • With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you.
    • If the battery is not coming out with this technique, use the plastic opening tool.
Elizabeth Ofori
648 Reputation
6 Guides authored
SUNY Cortland, Team 1-2, Getto Spring 2013 Member of SUNY Cortland, Team 1-2, Getto Spring 2013
SUNYCORT-GETTO-S13S1G2
5 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 11
All Time: 765
