HTC Desire V Rear Facing Camera Replacement
  1. HTC Desire V Rear Facing Camera Replacement, Battery: step 1, image 1 of 3 HTC Desire V Rear Facing Camera Replacement, Battery: step 1, image 2 of 3 HTC Desire V Rear Facing Camera Replacement, Battery: step 1, image 3 of 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Rear Facing Camera Replacement: step 2, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 2, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 2, image 3 of 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Rear Facing Camera Replacement, Midframe: step 3, image 1 of 3 HTC Desire V Rear Facing Camera Replacement, Midframe: step 3, image 2 of 3 HTC Desire V Rear Facing Camera Replacement, Midframe: step 3, image 3 of 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Rear Facing Camera Replacement: step 4, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 4, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 4, image 3 of 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Rear Facing Camera Replacement, Button Assembly: step 5, image 1 of 2 HTC Desire V Rear Facing Camera Replacement, Button Assembly: step 5, image 2 of 2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Rear Facing Camera Replacement: step 6, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 6, image 2 of 2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Rear Facing Camera Replacement: step 7, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 7, image 2 of 2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
  8. HTC Desire V Rear Facing Camera Replacement, Vibration Motor: step 8, image 1 of 2 HTC Desire V Rear Facing Camera Replacement, Vibration Motor: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the vibration motor shown from the white plug on the motherboard.
    • You will probably need tweezers to do this.
  9. HTC Desire V Rear Facing Camera Replacement: step 9, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 9, image 2 of 2
    • Gently remove the motor from its housing in the phone’s chassis.
    • The easiest way to do this is to lever the motor out by its rotating end using the tweezers.
  10. HTC Desire V Rear Facing Camera Replacement, Motherboard Assembly: step 10, image 1 of 2 HTC Desire V Rear Facing Camera Replacement, Motherboard Assembly: step 10, image 2 of 2
    • Remove the black information sticker if this is the first time opening the handset.
  11. HTC Desire V Rear Facing Camera Replacement: step 11, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 11, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 11, image 3 of 3
    Buy
    • You should now see a black ribbon cable, which was connected at the left to the Nav board, and on the right, to a gold ribbon cable which goes to the screen.
    • Unlock the gold ribbon cable connecting screen to logic board by lifting the locking tab at the back of the socket.
    • For this you may wish to use a spudger or tweezers.
  12. HTC Desire V Rear Facing Camera Replacement: step 12, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 12, image 2 of 2
    • Disconnect gold ribbon cable connecting screen to logic board by pulling cable out gently.
  13. HTC Desire V Rear Facing Camera Replacement: step 13, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 13, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 13, image 3 of 3
    • Gently unstick black ribbon cable from the chassis.
  14. HTC Desire V Rear Facing Camera Replacement: step 14, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 14, image 2 of 2
    • Unscrew the 2mm silver screw from top left.
    • Use a Phillips PH00 Screwdriver for this.
  15. HTC Desire V Rear Facing Camera Replacement: step 15, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 15, image 2 of 2
    • Gently pry logic board from the casing by lifting the left side up, as if there was a hinge on the right, folding it over the right edge where you will see a gold/orange ribbon cable.
  16. HTC Desire V Rear Facing Camera Replacement: step 16, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 16, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 16, image 3 of 3
    • Remove the gold ribbon cable by lifting tab at the back of the socket, using a spudger or tweezers.
  17. HTC Desire V Rear Facing Camera Replacement: step 17, image 1 of 2 HTC Desire V Rear Facing Camera Replacement: step 17, image 2 of 2
    • Gently pull the logic board to the right and it will disconnect from the chassis.
  18. HTC Desire V Rear Facing Camera Replacement, Motherboard: step 18, image 1 of 3 HTC Desire V Rear Facing Camera Replacement, Motherboard: step 18, image 2 of 3 HTC Desire V Rear Facing Camera Replacement, Motherboard: step 18, image 3 of 3
    • Noting that the rear side of the black ribbon cable is gold, use a spudger or an opening tool to gently disconnect it from the motherboard by levering it up at the right side
  19. HTC Desire V Rear Facing Camera Replacement: step 19, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 19, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 19, image 3 of 3
    Buy
    • Gently unplug and remove antenna cable (black antenna) from socket beside the ribbon cable
    • If you lack usable nails, you will need tweezers
  20. HTC Desire V Rear Facing Camera Replacement: step 20, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 20, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 20, image 3 of 3
    • Locate the camera.
    • Lift the locking tab at the back of the connector for the camera using tweezers or opening tools.
  21. HTC Desire V Rear Facing Camera Replacement: step 21, image 1 of 3 HTC Desire V Rear Facing Camera Replacement: step 21, image 2 of 3 HTC Desire V Rear Facing Camera Replacement: step 21, image 3 of 3
    • Preferably using tweezers, gently pull the camera assembly up from the motherboard, and away from the connector and the ribbon cable will slide out easily.
William McCusker
1,096 Reputation
9 Guides authored
Clemson, Team 14-3, Shirley Winter 2015 Member of Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 193
