HTC Desire V Button Assembly Replacement
  1. HTC Desire V Button Assembly Replacement, Battery: step 1, image 1 of 3 HTC Desire V Button Assembly Replacement, Battery: step 1, image 2 of 3 HTC Desire V Button Assembly Replacement, Battery: step 1, image 3 of 3
    • Gently pry back cover away from phone.
    • If you are having difficulty you may need to use a Spudger or plastic opener.
  2. HTC Desire V Button Assembly Replacement: step 2, image 1 of 3 HTC Desire V Button Assembly Replacement: step 2, image 2 of 3 HTC Desire V Button Assembly Replacement: step 2, image 3 of 3
    • Lever the battery out from the bottom end first.
    • Do not bend or puncture the battery.
  3. HTC Desire V Button Assembly Replacement, Midframe: step 3, image 1 of 3 HTC Desire V Button Assembly Replacement, Midframe: step 3, image 2 of 3 HTC Desire V Button Assembly Replacement, Midframe: step 3, image 3 of 3
    • Use a Torx T5 screwdriver to unscrew and remove five 3.0 mm screws from the rear frame.
  4. HTC Desire V Button Assembly Replacement: step 4, image 1 of 3 HTC Desire V Button Assembly Replacement: step 4, image 2 of 3 HTC Desire V Button Assembly Replacement: step 4, image 3 of 3
    • Use an opening tool or a spudger to gently remove the rear frame.
  5. HTC Desire V Button Assembly Replacement, Button Assembly: step 5, image 1 of 2 HTC Desire V Button Assembly Replacement, Button Assembly: step 5, image 2 of 2
    • Remove the connector on left side of the Navigation board by unplugging/prying the orange ribbon.
  6. HTC Desire V Button Assembly Replacement: step 6, image 1 of 2 HTC Desire V Button Assembly Replacement: step 6, image 2 of 2
    • Gently unplug and remove aerial cable (black antenna) from bottom plug.
  7. HTC Desire V Button Assembly Replacement: step 7, image 1 of 2 HTC Desire V Button Assembly Replacement: step 7, image 2 of 2
    • Nav Board will be stuck down by glue.
    • Pull gently from the right end of the board, being careful of its flexibility.
3 other people completed this guide.
William McCusker
1,096 Reputation
9 Guides authored
Clemson, Team 14-3, Shirley Winter 2015 Member of Clemson, Team 14-3, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G3
6 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 318
