HTC Desire 610 Charging Port Replacement
  1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: step 1, image 1 of 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: step 1, image 2 of 3 HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: step 1, image 3 of 3
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Charging Port Replacement: step 2, image 1 of 1
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Charging Port Replacement: step 3, image 1 of 1
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Charging Port Replacement: step 4, image 1 of 1
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Charging Port Replacement: step 5, image 1 of 1
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Charging Port Replacement, Charging Port: step 6, image 1 of 1
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  7. HTC Desire 610 Charging Port Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Using a pair of tweezers, disconnect the antenna wire.
  8. HTC Desire 610 Charging Port Replacement: step 8, image 1 of 3 HTC Desire 610 Charging Port Replacement: step 8, image 2 of 3 HTC Desire 610 Charging Port Replacement: step 8, image 3 of 3
    • Peel back the gray adhesive strip using the precision tweezers.
  9. HTC Desire 610 Charging Port Replacement: step 9, image 1 of 1
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  10. HTC Desire 610 Charging Port Replacement: step 10, image 1 of 3 HTC Desire 610 Charging Port Replacement: step 10, image 2 of 3 HTC Desire 610 Charging Port Replacement: step 10, image 3 of 3
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  11. HTC Desire 610 Charging Port Replacement: step 11, image 1 of 3 HTC Desire 610 Charging Port Replacement: step 11, image 2 of 3 HTC Desire 610 Charging Port Replacement: step 11, image 3 of 3
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
2 other people completed this guide.
Kaycee Hammond
273 Reputation
2 Guides authored
IUPUI, Team S1-G1, Wilson Spring 2017 Member of IUPUI, Team S1-G1, Wilson Spring 2017
IUPUI-WILSON-S17S1G1
4 Members
6 Guides authored
One Comment
Super duper 5
Nizamcdk - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 1,238
