HTC Touch Pro CDMA Screen Replacement
  1. HTC Touch Pro CDMA Screen Replacement, Battery: step 1, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Battery: step 1, image 2 of 2
    • First, gently press on the back plate and push down toward the camera.
  2. HTC Touch Pro CDMA Screen Replacement: step 2, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 2, image 2 of 2
    • Use your finger to lift up the edge of the battery.
  3. HTC Touch Pro CDMA Screen Replacement, USB Logic Board: step 3, image 1 of 1
    • Remove the 4 screws using the T6 screw driver.
  4. HTC Touch Pro CDMA Screen Replacement: step 4, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 4, image 2 of 2
    • Lift the plastic cover near the memory card slot.
  5. HTC Touch Pro CDMA Screen Replacement: step 5, image 1 of 1
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. HTC Touch Pro CDMA Screen Replacement: step 6, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 6, image 2 of 2
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  7. HTC Touch Pro CDMA Screen Replacement: step 7, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 7, image 2 of 2
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  8. HTC Touch Pro CDMA Screen Replacement: step 8, image 1 of 2 HTC Touch Pro CDMA Screen Replacement: step 8, image 2 of 2
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  9. HTC Touch Pro CDMA Screen Replacement, Keyboard: step 9, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Keyboard: step 9, image 2 of 2
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  10. HTC Touch Pro CDMA Screen Replacement, Screen: step 10, image 1 of 2 HTC Touch Pro CDMA Screen Replacement, Screen: step 10, image 2 of 2
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  11. HTC Touch Pro CDMA Screen Replacement: step 11, image 1 of 1
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  12. HTC Touch Pro CDMA Screen Replacement: step 12, image 1 of 1
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  13. HTC Touch Pro CDMA Screen Replacement: step 13, image 1 of 3 HTC Touch Pro CDMA Screen Replacement: step 13, image 2 of 3 HTC Touch Pro CDMA Screen Replacement: step 13, image 3 of 3
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
3 other people completed this guide.
Zhaowei Zhang
133 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,616
