HP Photosmart Plus Ink Replacement
Grammatical Errors
Grammatical Errors
This guide has grammatical errors or does not meet iFixit's writing guidelines.
Incorrect Text
Incorrect Text
This guide contains steps with ambiguous, improper, duplicate, misleading, or off-topic text.
Unsatisfactory Images
This guide has low-quality images. Pictures need to be either re-edited or re-taken.
User-Contributed Guide
This guide is not managed by iFixit staff.
Changing ink in an HP Photosmart Plus printer.
  • Author: nick
  • Difficulty: Very easy
  • Add Note x
this one uses individual ink and just as easy.
Uses 564 or 564XL but the shape that is printed has to match if replacing a empty ink or it will say "incompatible cartridge".
so,i recommend you bring the old ink to the store and match the shape if not refilling or getting remanufactured or having a pro refill
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — HP Photosmart Plus Ink Replacement  ¶
  • Turn on the printer pressing the power button on the front and lift the handle i highlighted in red
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Wait for the carrier to come to the middle of the printer by opening the printers lid from the handle in the first picture
first image
thumb image 1
thumb image 2
Add Note Edit Step 3  ¶
  • There is a snap built in to the ink that just needs a little pressure to come out from the printer as shown in this series of pictures
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Line up the ink with the printhead and the knotch it belongs to, then push down
  • But this,unlike the c4780,you can stick a Cyan ink into Magenta but it will read "incorrect print cartridge" and leave the stain of the wrong ink (thus you need to clean the stain out)
  • The black cartridge can be a challenge to fit correctly, especially if it is the standard capacity. The slot is better fit a larger capacity cartridge which is better then the standard so i recommend the XL over standard
For more information, check out the hp photosmart plus device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
