HP x2 10-p010wm Speaker Replacement
  1. HP x2 10-p010wm Speaker Replacement, Battery: step 1, image 1 of 1
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Speaker Replacement: step 2, image 1 of 2 HP x2 10-p010wm Speaker Replacement: step 2, image 2 of 2
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Speaker Replacement: step 3, image 1 of 1
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Speaker Replacement: step 4, image 1 of 1
    • Remove the eight 4mm Phillips #00 screws from the metal plate.
  5. HP x2 10-p010wm Speaker Replacement: step 5, image 1 of 3 HP x2 10-p010wm Speaker Replacement: step 5, image 2 of 3 HP x2 10-p010wm Speaker Replacement: step 5, image 3 of 3
    • Slowly peel up any tape securing the wire to the metal cover.
    • Remove the metal cover to access the battery.
  6. HP x2 10-p010wm Speaker Replacement: step 6, image 1 of 1
    • Remove the 4mm screw on the side.
  7. HP x2 10-p010wm Speaker Replacement: step 7, image 1 of 1
    • Remove the black tape.
    • Pull the battery connector towards the battery to disconnect it from its socket.
  8. HP x2 10-p010wm Speaker Replacement: step 8, image 1 of 1
    • Remove the battery.
  9. HP x2 10-p010wm Speaker Replacement, Speaker: step 9, image 1 of 2 HP x2 10-p010wm Speaker Replacement, Speaker: step 9, image 2 of 2
    • Remove speakers on both sides.
Nathan Ojala
317 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 170
