HP x2 10-p010wm Screen Replacement
  1. HP x2 10-p010wm Screen Replacement, Screen: step 1, image 1 of 2 HP x2 10-p010wm Screen Replacement, Screen: step 1, image 2 of 2
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Screen Replacement: step 2, image 1 of 2 HP x2 10-p010wm Screen Replacement: step 2, image 2 of 2
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Screen Replacement: step 3, image 1 of 1
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Screen Replacement: step 4, image 1 of 3 HP x2 10-p010wm Screen Replacement: step 4, image 2 of 3 HP x2 10-p010wm Screen Replacement: step 4, image 3 of 3
    • Hold the screen with your thumb and push back on the plastic frame.
    • Slowly separate the plastic frame on all sides.
    • Be careful not to break the plastic frame.
  5. HP x2 10-p010wm Screen Replacement: step 5, image 1 of 2 HP x2 10-p010wm Screen Replacement: step 5, image 2 of 2
    • Remove the frame.
Nathan Ojala
317 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 383
