HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: step 1, image 1 of 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: step 2, image 1 of 2 HP rp5700 Cover Removal Replacement: step 2, image 2 of 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: step 3, image 1 of 3 HP rp5700 Cover Removal Replacement: step 3, image 2 of 3 HP rp5700 Cover Removal Replacement: step 3, image 3 of 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
11 other people completed this guide.
Alyssa Briones
1,699 Reputation
9 Guides authored
Cal Poly, Team 6-23, Maness Winter 2014 Member of Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 103
All Time: 21,577
