Introduction
The Touchsmart 600 comes with a Core 2 Duo stock CPU, but the CPU is socketed so it can be removed and upgraded.
Flip the computer screen down, and flip the cover on the stand up.
Remove the screw and slide the panel down to remove the cover.
Unscrew the 4 screws holding the stand to the computer and pull the stand down to remove it.
Pull up on the bezel from the bottom. As long as you are careful, you should be able to remove them without breaking any clips
Pull up on the bottom of the panel and hinge it.
It will come off, set it aside
Unscrew the plate over the CPU
It uses a small phillips head, one of the only non torx bits in the computer
After unscrewing the plate, flip the fan off of the CPU
