HP Stream x360 11-p015wm Keyboard Replacement
  1. HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: step 1, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement, Back Cover: step 1, image 2 of 2
    • Orient the laptop to have the back cover facing upwards.
    • Remove the four rubber pads located in each corner.
  2. HP Stream x360 11-p015wm Keyboard Replacement: step 2, image 1 of 1
    Tool used on this step:
    JIS Driver Set
    $19.99
    Buy
    • Tool required: JIS #1 Screwdriver
    • Using the screwdriver, remove all of the exposed screws.
  3. HP Stream x360 11-p015wm Keyboard Replacement: step 3, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 3, image 2 of 2
    iFixit Opening Tool
    $1.99
    Buy
    • Tool required: iFixit opening tool
    • Open the laptop and orient the keyboard facing upward.
    • Slowly wedge the opening tool into the gap between the keyboard and the back cover.
    • After loosening the back cover, close the laptop and orient the back cover facing upward. Open the cover.
  4. HP Stream x360 11-p015wm Keyboard Replacement: step 4, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 4, image 2 of 2
    $3.99
    Buy
    • This is a good time to clean any accumulated dust or debris. Use this link on tips for cleaning.
    • Tool required: Tweezers
    • Carefully use tweezers to remove the audio jack connector from the motherboard.
  5. HP Stream x360 11-p015wm Keyboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove the six 6.5 mm Phillips head screws from the battery using the JIS #00 screwdriver.
  6. HP Stream x360 11-p015wm Keyboard Replacement: step 6, image 1 of 3 HP Stream x360 11-p015wm Keyboard Replacement: step 6, image 2 of 3 HP Stream x360 11-p015wm Keyboard Replacement: step 6, image 3 of 3
    • Unplug the wire attaching to the battery to the motherboard using the tweezers.
    • Remove the battery.
  7. HP Stream x360 11-p015wm Keyboard Replacement: step 7, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 7, image 2 of 2
    • Remove the six 3.5 mm screws from the silver plate cover with screwdriver JIS #00.
    • Remove the silver plate cover.
  8. HP Stream x360 11-p015wm Keyboard Replacement: step 8, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 8, image 2 of 2
    • Remove the four 3.5 mm screws from the metal arm using the JIS #00 screwdriver.
  9. HP Stream x360 11-p015wm Keyboard Replacement: step 9, image 1 of 3 HP Stream x360 11-p015wm Keyboard Replacement: step 9, image 2 of 3 HP Stream x360 11-p015wm Keyboard Replacement: step 9, image 3 of 3
    • Detach all remaining wires from the motherboard using the tweezers.
  10. HP Stream x360 11-p015wm Keyboard Replacement: step 10, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 10, image 2 of 2
  11. HP Stream x360 11-p015wm Keyboard Replacement: step 11, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 11, image 2 of 2
    • Remove the six 3.5 mm screws from the motherboard using the JIS #00 screwdriver.
    • Remove the motherboard.
  12. HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: step 12, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement, Keyboard: step 12, image 2 of 2
    • Remove the three 6.5 mm screws from the second screen hinge and metal arm using the JIS #00 screwdriver.
    • Remove the metal bracket.
  13. HP Stream x360 11-p015wm Keyboard Replacement: step 13, image 1 of 1
    • Remove the two 3.5 mm screws from the small sideboard using the JIS #00 screwdriver.
  14. HP Stream x360 11-p015wm Keyboard Replacement: step 14, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 14, image 2 of 2
    • Use the blue plastic opening tool to pry up the silver keyboard cover.
    • Remove the keyboard cover.
  15. HP Stream x360 11-p015wm Keyboard Replacement: step 15, image 1 of 2 HP Stream x360 11-p015wm Keyboard Replacement: step 15, image 2 of 2
    • Remove the keyboard.
Megan Waxman
139 Reputation
1 Guide authored
IUPUI, Team S2-G3, Stella Fall 2019 Member of IUPUI, Team S2-G3, Stella Fall 2019
IUPUI-STELLA-F19S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 241
