HP Stream 8 Button Board Replacement
  1. HP Stream 8 Button Board Replacement, Button Board: step 1, image 1 of 1
    • Use your nail to pry up the back cover of the device.
  2. HP Stream 8 Button Board Replacement: step 2, image 1 of 1
    • Fully remove the back cover.
  3. HP Stream 8 Button Board Replacement: step 3, image 1 of 3 HP Stream 8 Button Board Replacement: step 3, image 2 of 3 HP Stream 8 Button Board Replacement: step 3, image 3 of 3
    • Remove the 10 3mm screws using the Phillips #00 screwdriver.
  4. HP Stream 8 Button Board Replacement: step 4, image 1 of 2 HP Stream 8 Button Board Replacement: step 4, image 2 of 2
    • Pry up the inside cover the same way as you did with the back cover and fully remove it.
  5. HP Stream 8 Button Board Replacement: step 5, image 1 of 2 HP Stream 8 Button Board Replacement: step 5, image 2 of 2
    • Disconnect the button board from the motherboard and remove it.
Ashley Eimers
265 Reputation
2 Guides authored
IUPUI, Team S1-G3, Harley Spring 2019 Member of IUPUI, Team S1-G3, Harley Spring 2019
IUPUI-HARLEY-S19S1G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 14
All Time: 207
