HP Stream 11-y012nr WiFi Card Replacement
  1. HP Stream 11-y012nr WiFi Card Replacement, WiFi Card: step 1, image 1 of 3 HP Stream 11-y012nr WiFi Card Replacement, WiFi Card: step 1, image 2 of 3 HP Stream 11-y012nr WiFi Card Replacement, WiFi Card: step 1, image 3 of 3
    • Before disassembling the laptop, make sure to power off the device and unplug it from the charger.
    • Turn the laptop over to access lower case.
    • Using a metal spudger, remove the two horizontal screw covers.
  2. HP Stream 11-y012nr WiFi Card Replacement: step 2, image 1 of 2 HP Stream 11-y012nr WiFi Card Replacement: step 2, image 2 of 2
    • Remove the seven 5.6 mm Phillips #00 screws.
  3. HP Stream 11-y012nr WiFi Card Replacement: step 3, image 1 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 3, image 2 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 3, image 3 of 3
    • When using the metal spudger, be careful to not press into the components and circuits under the keyboard.
    • Turn the laptop upright and lift the screen.
    • Use metal spudger to carefully pry the plastic keyboard from the base of the laptop.
    • Work the spudger carefully and slowly around the cover to release the clips holding it together. Be sure to be patient since there are a lot of clips attaching the laptop base to the keyboard.
    • Gently lift up the keyboard.
  4. HP Stream 11-y012nr WiFi Card Replacement: step 4, image 1 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 4, image 2 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • The cover is attached by multiple cables. Be careful not to lift the cover too far so you do not damage these cables.
    • Using tweezers, unplug the three cables attached to the keyboard. To do so you will find where the wires end (the three red marks). The next step is to use tweezers or your fingers to pinch the plastic piece holding the wires, and gently pull the piece out. After that it should disconnect.
    • Remove the plastic keyboard cover.
  5. HP Stream 11-y012nr WiFi Card Replacement: step 5, image 1 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 5, image 2 of 3 HP Stream 11-y012nr WiFi Card Replacement: step 5, image 3 of 3
    • Remove the one 3.3mm Phillips #000 screw near the WiFi card.
    • Gently lift the WiFi card up.
    • Using tweezers, carefully disconnect the two wires from the WiFi card.
Terrell Cloud
121 Reputation
1 Guide authored
UC Davis, Team S18-G8, Lore Winter 2019 Member of UC Davis, Team S18-G8, Lore Winter 2019
UCD-LORE-W19S18G8
3 Members
3 Guides authored
2 Comments
Can you put the rubber feet back on after you take them off?
PugLoverz - Reply
Hi I have tried every thing I got a brief connection but upon shut down and restart all was back no WIFI
MY OLD eE 1000H runs ring around this beast
Bryan Watson - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 785
