HP Split x2 Trackpad Replacement
  1. HP Split x2 Trackpad Replacement, Trackpad: step 1, image 1 of 3 HP Split x2 Trackpad Replacement, Trackpad: step 1, image 2 of 3 HP Split x2 Trackpad Replacement, Trackpad: step 1, image 3 of 3
    • Remove the bumpers at the back of the keyboard part.
    • Use a J1 screwdriver head to remove the 7mm screws underneath the bumpers.
  2. HP Split x2 Trackpad Replacement: step 2, image 1 of 2 HP Split x2 Trackpad Replacement: step 2, image 2 of 2
    • Use a J1 screwdriver head to remove the remaining 5mm screws at the back of the keyboard part.
  3. HP Split x2 Trackpad Replacement: step 3, image 1 of 1
    • Use the opening tool to carefully remove the back cover of the keyboard.
  4. HP Split x2 Trackpad Replacement: step 4, image 1 of 1
    • Use a J1 screwdriver head to remove the black 2mm screws along the top part of the trackpad
    • Using the same screwdriver head, remove the black 3mm screws along the bottom part of the trackpad
  5. HP Split x2 Trackpad Replacement: step 5, image 1 of 1
    • Disconnect the ribbon cable and move it out of the way.
  6. HP Split x2 Trackpad Replacement: step 6, image 1 of 1
    • Slide the trackpad out from underneath the ribbon cables.
Jose Francisco
137 Reputation
1 Guide authored
IUPUI, Team S6-G6, Wilson Spring 2017 Member of IUPUI, Team S6-G6, Wilson Spring 2017
IUPUI-WILSON-S17S6G6
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,578
