HP Spectre x360 13-aw0xxx Battery Replacement
  1. HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: step 1, image 1 of 2 HP Spectre x360 13-aw0xxx Battery Replacement, Lower Case: step 1, image 2 of 2
    • Remove the following screws securing the lower case:
    • Four Phillips #00 6 mm screws
    • Two T5 Torx 3 mm screws
  2. HP Spectre x360 13-aw0xxx Battery Replacement: step 2, image 1 of 1
    • Insert an opening tool in the seam between the lower case and chassis.
    • Pry around the perimeter until the lower case fully releases.
    • Remove the lower case.
  3. HP Spectre x360 13-aw0xxx Battery Replacement, Battery: step 3, image 1 of 2 HP Spectre x360 13-aw0xxx Battery Replacement, Battery: step 3, image 2 of 2
    • Use two opening tools, one on either side of the battery plug, to slowly pull the plug straight out of its port.
    • Alternatively, use your fingernails.
  4. HP Spectre x360 13-aw0xxx Battery Replacement: step 4, image 1 of 2 HP Spectre x360 13-aw0xxx Battery Replacement: step 4, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws securing the battery.
  5. HP Spectre x360 13-aw0xxx Battery Replacement: step 5, image 1 of 2 HP Spectre x360 13-aw0xxx Battery Replacement: step 5, image 2 of 2
    • Carefully lift the edge of the battery with an opening tool.
    • Lift the battery up and out.
Thomas Hayslett
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 38
Past 30 Days: 156
All Time: 1,377
