HP Photosmart Premium C309g TouchSmart Display Screen Replacement
  1. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement, TouchSmart Display Screen: step 1, image 1 of 1
    • Open the top of printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 2, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 2, image 2 of 2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 3, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 3, image 2 of 2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 4, image 1 of 1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 5, image 1 of 1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 6, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 6, image 2 of 2
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 7, image 1 of 1
    • Gently pull the display screen away from the printer.
    • Locate & unscrew the two 12mm screws using the T9 Torx Security screwdriver bit.
  8. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 8, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 8, image 2 of 2
    • Place thumb and forefinger where shown and pull this piece away from the printer.
    • Do not pull it away too hard. The piece is still connected by wiring ribbon.
  9. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 9, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 9, image 2 of 2
    • Pull both wiring ribbons out from the display screen piece. This will separate the piece from the printer.
    • Use tweezers if necessary.
  10. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 10, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 10, image 2 of 2
    • Push forward and down to release the retaining piece. This will detach the display screen from the front panel.
  11. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 11, image 1 of 1
    • Set the display screen face down.
    • Locate and unscrew all four 12mm screws on the back on the display screen using the T9 Torx Security screwdriver bit.
  12. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 12, image 1 of 1
    • Lift the back of the display screen to remove it.
  13. HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 13, image 1 of 2 HP Photosmart Premium C309g TouchSmart Display Screen  Replacement: step 13, image 2 of 2
    • Place hands as shown and push with your thumbs to detach the plastic from the screen.
Laura
694 Reputation
3 Guides authored
Michigan Tech, Team 1-2, Lauer Fall 2014 Member of Michigan Tech, Team 1-2, Lauer Fall 2014
MTU-LAUER-F14S1G2
3 Members
5 Guides authored
One Comment
where can i get replacement part
fernando - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 17
All Time: 1,188
