HP Pavilion dv7-3065dx Hard Drive Replacement
  1. HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: step 1, image 1 of 2 HP Pavilion dv7-3065dx Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx Hard Drive Replacement: step 2, image 1 of 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion dv7-3065dx Hard Drive Replacement: step 3, image 2 of 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Loosen the four screws that secure the hard drive panel with a Phillips head screwdriver.
    • Do not completely remove the screws from the panel.
  5. HP Pavilion dv7-3065dx Hard Drive Replacement: step 5, image 1 of 1
    • Lift the drive cover to expose the hard drive.
    • This device did not have a physical hard drive to work with.
    • Gently tug on the black tabs located on each end of the hard drive in order to loosen the hard drive from the motherboard.
    • Be careful when working with the hard drive cable.
    • Separate the hard drive from the cable by firmly gripping the hard drive and the black plug.
    • Remove the four Phillips screws that secure the hard drive to its carrier.
    • There are two screws on each side.
    • Lift and remove the hard drive from the metal surrounding its perimeter.
2 other people completed this guide.
Gabi Marino
157 Reputation
1 Guide authored
Ohio State, Team 1-5, Wilder Spring 2017 Member of Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 3,513
