HP Pavilion dv1000 Keyboard Replacement
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: step 2, image 1 of 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: step 3, image 1 of 2 HP Pavilion dv1000 Keyboard Replacement: step 3, image 2 of 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: step 4, image 1 of 3 HP Pavilion dv1000 Keyboard Replacement: step 4, image 2 of 3 HP Pavilion dv1000 Keyboard Replacement: step 4, image 3 of 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: step 6, image 1 of 2 HP Pavilion dv1000 Keyboard Replacement: step 6, image 2 of 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Tyler Latour
266 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 19
All Time: 1,601
