HP Pavilion ZD7000 Wi-Fi Card Replacement
  1. HP Pavilion ZD7000 Wi-Fi Card Replacement, Battery: step 1, image 1 of 1
    • Begin by turning the laptop over so that you can see the bottom of the computer.
  2. HP Pavilion ZD7000 Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide the battery release switch to the right while simultaneously lifting up the battery.
  3. HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 2 HP Pavilion ZD7000 Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 2
    • Unscrew the 2 screws from the plate that cover the Wi-Fi card.
    • Remove the cover.
  4. HP Pavilion ZD7000 Wi-Fi Card Replacement: step 4, image 1 of 2 HP Pavilion ZD7000 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Disconnect these 2 antenna wires (which eventually connect to the monitor) from the Wi-Fi card.
    • For reassembly, note where the black and white cables connect to the card.
    • Release the Wi-Fi card from the laptop by pressing the metal hinges on either end of it.
    • Gently remove the card from laptop.
3 other people completed this guide.
Shantel
545 Reputation
6 Guides authored
Cal Poly, Team 30-37, Garner Spring 2010 Member of Cal Poly, Team 30-37, Garner Spring 2010
CPSU-GARNER-S10S30G37
4 Members
6 Guides authored
2 Comments
Can you upgrade the wifi card?
danoco - Reply
is there a replacement I can buy
Braeden Culp - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 12
All Time: 5,443
