HP Pavilion Wave 600-a014 System Fan Replacement
  1. HP Pavilion Wave 600-a014 System Fan Replacement, Hard Drive: step 1, image 1 of 1
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 System Fan Replacement: step 2, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 2, image 2 of 2
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 System Fan Replacement: step 3, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 3, image 2 of 2
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 System Fan Replacement: step 4, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 4, image 2 of 2
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 System Fan Replacement: step 5, image 1 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 5, image 2 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 5, image 3 of 3
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 System Fan Replacement: step 6, image 1 of 1
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
  7. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: step 7, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: step 7, image 2 of 2
    • After removing your hard drive, remove the two 1.2mm Phillips #1 screws from the bottom of your case .
  8. HP Pavilion Wave 600-a014 System Fan Replacement: step 8, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 8, image 2 of 2
    • Remove the 8 mm Phillips #0 screw that is connected the top bezel and the top cover using the driver kit.
  9. HP Pavilion Wave 600-a014 System Fan Replacement: step 9, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 9, image 2 of 2
    • Using a flathead screwdriver, remove the 8 mm Phillips #1 screw that connects the body casing and the top bezel(the one at the bottom of memory card slot).
  10. HP Pavilion Wave 600-a014 System Fan Replacement: step 10, image 1 of 1
    • Remove the top bezel.
    • You will have to take off a pair of wire connecting the bezel with the body to be able to completely detach it.
  11. HP Pavilion Wave 600-a014 System Fan Replacement: step 11, image 1 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 11, image 2 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 11, image 3 of 3
    • Turn the device to the top side where you can see the top cover and the speaker.
    • Using a flathead or Phillips #1 screwdriver, unscrew all the eight 8.0 mm screws that connect the top cover to the other components of the casing.
    • Gently remove the top cover.
  12. HP Pavilion Wave 600-a014 System Fan Replacement: step 12, image 1 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 12, image 2 of 3 HP Pavilion Wave 600-a014 System Fan Replacement: step 12, image 3 of 3
    • After removing the top cover, locate the system fan on the left side of memory compartment.
    • Remove three 1.2 cm Phillips #1 screws that connect the fan with the main body.
  13. HP Pavilion Wave 600-a014 System Fan Replacement: step 13, image 1 of 2 HP Pavilion Wave 600-a014 System Fan Replacement: step 13, image 2 of 2
    • Simply slide up the fan after removing the screws.
Kyaw Soe
321 Reputation
2 Guides authored
Cal Poly, Team S8-G4, Banghart Fall 2017 Member of Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,150
