HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement
  1. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: step 1, image 1 of 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Front IO Board: step 1, image 2 of 2
    • Turn over the computer and remove the rubber feet.
    • Remove the 8mm Philips screws indicated in red circles with a Philips #0 screwdriver.
    • Use a pry tool and lift the lid.
  2. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 2, image 1 of 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 2, image 2 of 2
    • Pry open the casing from the back of the IO panel, as shown in the pictures.
  3. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 3, image 1 of 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 3, image 2 of 2
    • Finally, remove the two cables circled in red from the front IO panel.
  4. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement, Mouse and Keyboard adapter: step 4, image 1 of 1
    • Locate a blue USB adapter on the left side of the hard disk compartment.
  5. HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 5, image 1 of 2 HP Pavilion Wave 600-a014 Mouse and Keyboard Replacement: step 5, image 2 of 2
    • Take off the USB with gentle but firm pressure.
    • This is a single USB adapter for both mouse and keyboard, so you must get a wireless mouse and keyboard pair, or you will have to use the extra USB for the other one.
4 other people completed this guide.
Kyaw Soe
321 Reputation
2 Guides authored
Cal Poly, Team S8-G4, Banghart Fall 2017 Member of Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Members
5 Guides authored
3 Comments
Seems like there might be enough room for a usb 2 port hub/splitter (such as Onvian USB Splitter Cable Male to 2 Female Adapter USB) to add an additional usb dongle (such an RF or Insteon USB)? Can you confirm how much room there are?
thomastranrx - Reply
Since it's a year old project, I forgot most of the dimensions, but from my memory, it would be possible since it's located in a little groove that can probably fit a wire or two. (You can see it in step one picture)
Kyaw Soe - Reply
Can i purchase this dongle anywhere? Is there any documentation on how to pair?
will - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 22
All Time: 2,314
