HP Pavilion DV5T-1000 Hard Drive Replacement
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  1. HP Pavilion DV5T-1000 Hard Drive Replacement: step 2, image 1 of 1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion DV5T-1000.
  2. HP Pavilion DV5T-1000 Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion DV5T-1000 Hard Drive Replacement: step 3, image 2 of 2
    • Slide the battery lock to the left, it's located just below the battery compartment.
    • Pull the battery up and out, to remove it from the battery compartment.
    • To prevent hardware damage, remove the battery before working on the laptop.
  3. HP Pavilion DV5T-1000 Hard Drive Replacement: step 4, image 1 of 1
    • Identify the hard drive compartment, located at the top left-hand frame of the laptop.
  4. HP Pavilion DV5T-1000 Hard Drive Replacement: step 5, image 1 of 1
    • In order to remove the hard drive compartment cover, first remove the two screws located on the panel, using a size 0 Phillips head screwdriver.
  5. HP Pavilion DV5T-1000 Hard Drive Replacement: step 6, image 1 of 1
    • Expose the hard drive by lifting the drive cover.
  6. HP Pavilion DV5T-1000 Hard Drive Replacement: step 7, image 1 of 1
    • In order to loosen the hard drive from the motherboard, tug gently on the black tabs located at both ends of the hard drive.
    • Be cautious when handling the cable that connects the hard drive to the computer's motherboard.
  7. HP Pavilion DV5T-1000 Hard Drive Replacement: step 8, image 1 of 2 HP Pavilion DV5T-1000 Hard Drive Replacement: step 8, image 2 of 2
    • Firmly hold both the black plug, and the hard drive itself to separate the drive from the cable.
  8. HP Pavilion DV5T-1000 Hard Drive Replacement: step 9, image 1 of 2 HP Pavilion DV5T-1000 Hard Drive Replacement: step 9, image 2 of 2
    • Remove the 4 screws using a size 0 Phillips head screwdriver.
    • Remove the metal from the perimeter of the hard drive.
4 other people completed this guide.
Josh Taimanglo
147 Reputation
1 Guide authored
One Comment
Help after replacing hard drive installation of windows
Bettyjean Serrano - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 47
All Time: 1,867
