HP Officejet Pro 8625 Left Side Panel Replacement
  1. HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: step 1, image 1 of 3 HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: step 1, image 2 of 3 HP Officejet Pro 8625 Left Side Panel Replacement, Left Side Panel: step 1, image 3 of 3
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Left Side Panel Replacement: step 2, image 1 of 3 HP Officejet Pro 8625 Left Side Panel Replacement: step 2, image 2 of 3 HP Officejet Pro 8625 Left Side Panel Replacement: step 2, image 3 of 3
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Left Side Panel Replacement: step 3, image 1 of 2 HP Officejet Pro 8625 Left Side Panel Replacement: step 3, image 2 of 2
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
Daniel
289 Reputation
2 Guides authored
Cal Poly, Team S13-G3, White Fall 2018 Member of Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 330
