HP OfficeJet 4650 Scanner Light Motor Replacement
  1. HP OfficeJet 4650 Scanner Light Motor Replacement, Scanner Light Motor: step 1, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement, Scanner Light Motor: step 1, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement, Scanner Light Motor: step 1, image 3 of 3
    • Open the cartridge access door by placing one hand on the grooves of each side and pulling up.
  2. HP OfficeJet 4650 Scanner Light Motor Replacement: step 2, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 2, image 2 of 2
    • Using the hex screwdriver, remove the 2.0 mm x 14 mm screw that binds the front cover to the printer body by turning the screw counterclockwise.
  3. HP OfficeJet 4650 Scanner Light Motor Replacement: step 3, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 3, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 3, image 3 of 3
    • Release the front panel from its internal hooks by applying a little force and sliding the front panel to the right.
    • Push the panel upward to remove it from the printer.
    • There is a connector attached to the back of the panel. Flip the front cover towards you gently and proceed to the next step.
  4. HP OfficeJet 4650 Scanner Light Motor Replacement: step 4, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 4, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 4, image 3 of 3
    • Remove the connector that is attached to the screen's circuit board by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
  5. HP OfficeJet 4650 Scanner Light Motor Replacement: step 5, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 5, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 5, image 3 of 3
    • Unhook the clip supporting the cartridge access door by using a plastic opening tool to get under the clip and using another hand to pull the clip from its hook.
  6. HP OfficeJet 4650 Scanner Light Motor Replacement: step 6, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 6, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 6, image 3 of 3
    • Release the clip by pushing the clip towards the inside of the printer and pulling the clip out.
  7. HP OfficeJet 4650 Scanner Light Motor Replacement: step 7, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 7, image 2 of 2
    • Remove the four 2.0 mm x 14 mm hex screws that bind the internal protective cover to the body by using a hex screwdriver and turning counterclockwise.
    • Remove the two 2.0 mm x 11 mm hex screws that bind the internal protective cover to the body by using a hex screwdriver and turning counterclockwise.
  8. HP OfficeJet 4650 Scanner Light Motor Replacement: step 8, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 8, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 8, image 3 of 3
    • Detach the left-side panel by applying downward pressure on the internal protective cover with one hand and pulling the left-side cover with the other.
  9. HP OfficeJet 4650 Scanner Light Motor Replacement: step 9, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 9, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 9, image 3 of 3
    • Pull the left-side cover clip away from the internal protective cover to unhook it from the left-side cover.
  10. HP OfficeJet 4650 Scanner Light Motor Replacement: step 10, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 10, image 2 of 2
    • Detach the right-side panel by applying downward pressure on the internal protective cover with one hand and pulling the right-side cover with the other.
  11. HP OfficeJet 4650 Scanner Light Motor Replacement: step 11, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 11, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 11, image 3 of 3
    • Detach the right-side panel by pulling the right-side cover clip away from the internal protective cover.
  12. HP OfficeJet 4650 Scanner Light Motor Replacement: step 12, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 12, image 2 of 2
    • Use both hands to lift the whole internal protective cover.
    • Gently flip the internal protective cover counterclockwise.
    • Be careful when lifting the internal protective cover. There is a connector attached to the cover.
  13. HP OfficeJet 4650 Scanner Light Motor Replacement: step 13, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 13, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 13, image 3 of 3
    • Remove the connector that binds the internal protective cover to the motherboard by pinching the blue part of the connector with two fingers and pulling it away from the motherboard.
  14. HP OfficeJet 4650 Scanner Light Motor Replacement: step 14, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 14, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 14, image 3 of 3
    • Remove the protective cover by lifting it away from the printer with both hands.
  15. HP OfficeJet 4650 Scanner Light Motor Replacement: step 15, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 15, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 15, image 3 of 3
    • Remove the connector that binds the cartridge access door to the motherboard by pinching the blue part of the connector with two fingers and pulling it away from the motherboard.
  16. HP OfficeJet 4650 Scanner Light Motor Replacement: step 16, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 16, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 16, image 3 of 3
    • Remove the cables that connect the cartridge access door to the motherboard by pinching the front of the cable box with two fingers and pulling it away from the motherboard.
  17. HP OfficeJet 4650 Scanner Light Motor Replacement: step 17, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 17, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 17, image 3 of 3
    • Flip the cartridge access door with two hands so that the non-glass side of the cartridge access door is on top.
  18. HP OfficeJet 4650 Scanner Light Motor Replacement: step 18, image 1 of 1
    • Remove the eight 2.0 mm x 14 mm hex screws on the back of the cartridge access door by using the hex screwdriver and rotating counterclockwise.
  19. HP OfficeJet 4650 Scanner Light Motor Replacement: step 19, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 19, image 2 of 2
    • Wedge the plastic opening tool into the creases on the sides of the cartridge access door to help detach the glass side from the back side of the cartridge access door in the next steps.
  20. HP OfficeJet 4650 Scanner Light Motor Replacement: step 20, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 20, image 2 of 2
    • Use a plastic opening tool to snap off the right-side clip and push the clip outward.
  21. HP OfficeJet 4650 Scanner Light Motor Replacement: step 21, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 21, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 21, image 3 of 3
    • Use a plastic opening tool to snap off the left-side clip and push the clip outward.
  22. HP OfficeJet 4650 Scanner Light Motor Replacement: step 22, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 22, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 22, image 3 of 3
    • Pieces from the inside of the scanner glass may fall out.
    • Detach the scanner glass by slowly moving the glass side away from the back side of the cartridge access door.
    • Find the rectangular scanner piece that has a white light strip.
  23. HP OfficeJet 4650 Scanner Light Motor Replacement: step 23, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 23, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 23, image 3 of 3
    • Flip the whole rectangular scanner light piece.
    • Remove the 2.0 mm screw by using a hex screwdriver and rotating the screw counterclockwise to detach the metal plate from the motor.
  24. HP OfficeJet 4650 Scanner Light Motor Replacement: step 24, image 1 of 2 HP OfficeJet 4650 Scanner Light Motor Replacement: step 24, image 2 of 2
    • Remove the metal plate by lifting it away from the motor.
  25. HP OfficeJet 4650 Scanner Light Motor Replacement: step 25, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 25, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 25, image 3 of 3
    • Remove the motor from its casing by holding the motor on both sides and pulling up.
  26. HP OfficeJet 4650 Scanner Light Motor Replacement: step 26, image 1 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 26, image 2 of 3 HP OfficeJet 4650 Scanner Light Motor Replacement: step 26, image 3 of 3
    • Remove the connector that is attached to the motor by pinching the blue part of the connector with two fingers and pulling it away from the circuit board.
Stephanie Carpintero
994 Reputation
5 Guides authored
Cal Poly, Team S19-G6, Livingston Winter 2018 Member of Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Members
10 Guides authored
One Comment
Most detailed instructions I've seen on-line!
Question...how do you determine where the problem is for the scanner to not work...from the power module, the cable, up to the lights and motor?
I don't have schematics or wiring diagrams.
Richard Irby - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,034
