HP OfficeJet 4650 Paper Tray Replacement
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: step 1, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: step 1, image 2 of 2
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: step 2, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement: step 2, image 2 of 2
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: step 3, image 1 of 3 HP OfficeJet 4650 Paper Tray Replacement: step 3, image 2 of 3 HP OfficeJet 4650 Paper Tray Replacement: step 3, image 3 of 3
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: step 4, image 1 of 2 HP OfficeJet 4650 Paper Tray Replacement: step 4, image 2 of 2
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: step 5, image 1 of 1
    • Remove the paper tray by pulling the tray away from the printer.
Stephanie Carpintero
994 Reputation
5 Guides authored
Cal Poly, Team S19-G6, Livingston Winter 2018 Member of Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Members
10 Guides authored
3 Comments
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Reply
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Reply
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Reply
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 31
All Time: 4,613
